I've just tried editing my first footage recorded with OBS but its damn near impossible as the preview screen in Vegas Pro is REALLY laggy and CPU usage jumps up to 100%
This is 100% an issue with the OBS footage as I can import ShadowPlay just fine. I've obviously missed some setting somewhere that's making the footage difficult for Vegas to deal with.
30min OBS footage lags a LOT in Vegas even with preview set to the LOWEST quality, CPU usage hits 100%, editing is impossible as system just locks up.
40min ShadowPlay footage is smooth as silk in Vegas even with preview set to HIGHEST settings, CPU usage hits 50%, editing is super smooth, no issues.
I have an Nvidia GPU (EVGA 1080ti SC2 Hybrid) and an i7-7700k @ 5.0Ghz, 16GB RAM @ 3000MHz and all the trimmings so my PC is more than capable which is proven by how well it handles 60fps 3440x1440 130bit rate Shadowplay footage.
I'm sure I followed these settings to the letter when setting OBS up but I must have missed something?: https://www.youtube.com/watch?v=svrpFWMkmd0
Here are my Output settings in OBS:
This is what my OBS footage looks like:
General
Complete name : D:\OBS Videos RAW - Copy\2017-09-10 16-51-11.mp4
Format : MPEG-4
Format profile : Base Media
Codec ID : isom (isom/iso2/avc1/mp41)
File size : 37.3 GiB
Duration : 29 min 14 s
Overall bit rate mode : Variable
Overall bit rate : 183 Mb/s
Writing application : Lavf57.66.102
Video
Format : AVC
Format/Info : Advanced Video Codec
Format profile : Main@L5.2
Format settings, CABAC : Yes
Format settings, RefFrames : 2 frames
Codec ID : avc1
Codec ID/Info : Advanced Video Coding
Bit rate : 182 Mb/s
Width : 3 440 pixels
Height : 1 440 pixels
Display aspect ratio : 2.40:1
Frame rate mode : Constant
Frame rate : 60.000 FPS
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.614
Stream size : 37.2 GiB (100%)
Color range : Limited
Matrix coefficients : BT.470 System B, BT.470 System G
Audio #1
Format : AAC
Format/Info : Advanced Audio Codec
Format profile : LC
Codec ID : 40
Duration : 29 min 13 s
Bit rate mode : Variable
Bit rate : 157 kb/s
Maximum bit rate : 160 kb/s
Channel(s) : 2 channels
Channel positions : Front: L R
Sampling rate : 44.1 kHz
Frame rate : 43.066 FPS (1024 SPF)
Compression mode : Lossy
Stream size : 32.9 MiB (0%)
Title : Mod-Mic 4
Default : Yes
Alternate group : 1
Audio #2
Format : AAC
Format profile : LC
Codec ID : 40
Bit rate mode : Constant
Bit rate : 163 kb/s
Stream size : 34.2 MiB (0%)
Title : Beyerdynamics DT990 Pro
Default : No
Alternate group : 1
General
Format : MPEG-4
Video
Format : AVC
Codec ID : avc1
Bit rate : 182 Mb/s
Color space : YUV
Bit depth : 8 bits
Audio #1
Format : AAC
Format profile : LC
Codec ID : 40
Bit rate : 157 kb/s
Title : Mod-Mic 4
Default : Yes
Alternate group : 1
Audio #2
Format : AAC
Format profile : LC
Codec ID : 40
Bit rate : 163 kb/s
Default : No
Alternate group : 1
